Need troubleshooting help
KenH
Portland, OR, USA
My Viper has developed an intermittent problem. Sometimes when giving it some throttle either from a stop or on the open road, it starts bucking like it is getting a complete power cut which is coming and going about once a second. Backing out of the throttle causes it to run OK.
It may be RPM dependent. Once when it was acting up, each time I slowly increased RPMs to a little over 3000RPM, it would start bucking. When it did. the WBO would read about 11:1 instead of the normal 14.7 A/F. It makes me think that I am getting an electrical cut of some kind. When I would let off the throttle, it would run OK. I have only noticed the problem at part throttle.
I checked the TPS and it seems to read smooth over its range. I'm thinking perhaps something like the crank position sensor or coil pack. I know if I just take it into the Tech, it will run fine.
RTTTTed
Sounds like it could be a bad connection. Pull connectors and re-install them a few times and see if that helps, before paying a mechanic to do it. No codes in the computer?
Ted
CROM
Fairfax, VA
On another car I had a primary 02 sensor go bad. The symptoms were the same as you describe above. Might be worth a check. Granted you would assume the car would throw a code..but these cars are quirky.
K
KenH
Portland, OR, USA
No codes. I'll try reseating the main connections as suggested.
I am driving it to see if I can get any more clues. I may just swap the O2's in an effort to shotgun the problem.
Purdue_Boiler_Viper
Indy
If you are going to pull the connectors, clean them up with electronics lube / cleaner. You can get it at RadioShack. I had a TR7 once that did this. Turned out to be the electronic ignition module intermittently failing. It finally failed completely, of course while I was trying to pass someone on the highway.
Purdue_Boiler_Viper
Indy
Haaa a TR7, the car I learned how to drive a manual when I was 17.
It was a good looking car, but what a piece of junk. I had the ignition problem, synchro problems in the transmission, and the car overheated and warped the head on the previous owner. Chicks dug it though.:2tu:
jpolen21
