New Pads. Resurface Rotors?
G-Fulm
Fairfax, VA
I am changing my 05 SRT-10 over to the EBC low-dust ceramic disc brake pads.
Question is, should the rotors be resurfaced while I'm at it?
Car has 28,000 miles on it. Thanks!
Dom426h
DE
Depends on the condition of the rotors. If they are grooved then you can resurface them. But keep in mind that when you resurface they are taking a decent cut off the top that is reducing the thermal capacity of the rotor. Im pretty sure that no-one doing trackdays resurfaces their rotors between pads. This might not be a concern for you if you do not participate in performance events.
If the rotors are relativly flat some shops just spin them on a shaft and use this drill attachement called a flex-hone.
Last time i switched pads my rear rotors were still in great condition so i simply sanded them evenly with a sanding block to remove the transfer layer left from the pads and lightly rough up the metal to allow the new pads to mate to the surface and bed in properly.
I ordered a flexhone for future self resurfacing.
This is what it looks like:
http://www.flexhone.com/
http://www.brushresearch.com/brushes.php?c1=6
F
FrgMstr
Guest
Just put new EBC Red on my 05 SRT-10 with used StopTech cross-drilled rotors. No problems at all. The rotors were in great condition. The EBC Red come with a coating to deglaze the rotors as you break those in, so no issues with it unless you rotors are grooved badly.
bluesrt
throw them old rotrs away- get new ones, and dont forget to bed those brakes so they dont squeek
G
G-Fulm
Fairfax, VA
Ok, probably wont resurface them then. Depends on the condition when I pull the calipers. Thanks.
AbsolutHank
Odenton, MD
Hey buddy...my Dad and I own a repair shop. If you wanted to take them off and we could meet up, I'd be more than happy to resurface them for you.
Lemme know!
AndyMac
Saint John, NB, Canada
Make sure if you get them turned down, you or the shop removes the "record player" type finish from them or it will reduce your braking power.
Bill Pemberton Woodhouse
Blair,Nebraska,USA
Take Ryan up on his kind offer ------ he can likely tell easily if resurfacing is in your best interest or if it is time to get a new set. Way cool, Ryan, nice to see the support , but then the Virginia/ Maryland Club always has been a good group!
Andy! I am always looking for a way to describe the grooves embedded in a rotor by the metallic particles in the pad: a Phonograph Record is PERFECT! Thanks. [Except the last 2 owners did not know what a 33-LP was!]
Leslie's post has hidden meaning: 'I turn my street rotors'.... Her Tracked rotors need MASS to handle the heat. Turning/resurfacing used rotors scores away MASS...and a too-thin rotor will warp quickly on track. Ask Around to club vendors: NEW front rotors are available for Gen 1-2-3-4 at under $150/pair, a GOOD investment if your rotors are record-grooved and old, 28K miles is a LOT to be resufvaced.....
xeng yang
