v10kingsnake
Majorly Beautimous!!!
I am going to remove the door opener. It doesn't bother me that much because the car isn't out that often really. Only thing that needs to be changed on the current door track setup is that a bigger radius track needs to be installed which will help hug the door higher to the 11 ft ceiling height I have in the garage. I believe I was quoted 500 to do this which is mostly a labor instense job.Nice color combination
Quote:
i found a local garage installer and he will be out tomorrow to advise the best way to proceed. will post what the end result is after i get home from the office.
What was decided on the garage door and operator mods??
Were the tracks special ordered?
Can you reuse the original operator?
How much to mod the door?
Inferno, I will be fine once the garage is modded. The ceiling is 11ft high, the lift goes 5'3" up I believe so a regular car should be very snug but fit fine under the viper when it's raised up.Can you get that high enough to fit another car underneath?
i dont have a problem with that bro. i live in south jersey off exit 4. i am busy this weekend doing some last minute xmas shopping and all but pm me your number and well talk about it.King... Nice set up . I'm still thinking between Bendpak and Revolution . Do you mine if I come over to see it in person so just to finalize my thingy . I'm located in Central Jersey not sure how far south you are. Let me know if it possible...
good advice, i was just worried about banging my noggin on those bad-boys hanging down but that is good to know. thanks guys for all the nice comments too. should have new pics with car raised soon.I paid $ 500.00 to have mine raised also. I did notice on my Revolution, if you leave the ramps on & lift them, watch where they contact the lift. Mine slightly bent one of the rods by hanging down on it.
Andy
easy, they sell a tray that fits between the rails to accomodate a jack to do just that.Quick question: with these types of lifts, how do you get the tires off te ramp to change wheels or to do suspension work? do you have to jack it up off the floor and use jack stands on the lift?
