Alternative
- Joined
- Jan 16, 2002
- Posts
- 294
- Reaction score
- 0
I found some product installation procedures at NX's website, and I put a basic system together based on the diagrams. It's a basic wet kit with purge valve and MSD rpm switch. Here's the wiring diagram I put together:
http://img.villagephotos.com/p/2003-6/239653/nxsystemwiringII.jpg
A few questions:
1. Is my wiring diagram correct?
2. Where (easiest spot on the Viper) do I tap the Tach signal wire from the MSD RPM switch?
3. I heard that the fuel pressure switch doesn't work well in the Viper. If I decide not to install it, do I connect the wire intended to the fuel pressure switch from the relay to a ground source?
A few questions:
