nitrous kit for viper?
Fast Freddy
TUCSON, AZ - USA
i will be buying a nitrous kit for my viper in the future and installing it. my question is this: how do all the different wet kits on the market go about supplying the additional fuel for the nitrous on their systems? do they have you install a seperate fuel pump and lines for this or do you use the existing stock fuel pump and lines and just t-off the lines to the fuel solenoid of the nitrous system? if the latter is the case i would assume if you want to run large shots of juice that you can just buy a bigger fuel pump and increase your fuel pressure. and finally one last question: does anybody know anyone that has run nos's dry nitrous kit (limited to 135 hp) on their viper and did it function problem free for them?
p.s. - i do not want to use anything other than race gas to fuel my nitrous system. so propane is not an option for me.
Jack B
NE Ohio
The fuel line goes into the schrader valve at the rear inside of the passenger fuel rail. You will have enough fuel pressure if you stay in the 200-300 hp range. Tuning for A/F before using the nos is the key to success. The dry system has a funky a/f curve. Take a look in "My Gallery" for a general NOS connection schematic.
00prowler
Vernon CT USA
I have a Nitrous Express GenX kit new in the box, has everything, best one on market, purge kit, bottle warmer etc, has 100, 150, 200 jets. 1000.00 delivered. I paid 1300.00 for it...00PROWLER
