noise from window 08?
VIPER 93
Same problem, regulator being fixed this week.
what dealership are you using?
A
adamlotus
los angeles
im taking it to valley dodge in van nuys,also when im on a bumpy road i her clunking noise from the rear of vehicle,like somrthings loose,maybe its normal noise but will have them check it out.
xjrguy
I had the clunking noise that you speak of as well and it was loose undertray bolts.
Tightened those bad suckas back up and no more noises.
A
adamlotus
los angeles
i had the rear diffuser and undertray bolts all checked if loose nothing,checked all the strut and control arm bolts everything is tight it just might be normal noise from the car.
General Jackson
