Oil sending unit leaking.
Two R/Ts
Olympia, Washington
Is this a common problem with Gen 2, the rubber plug and wire that connects to the unit keeps getting pushed out when oil pressure starts rising from startup, then leaks. Is this a blown out oil sending switch?
Dom426h
DE
Mine started leaving a couple drips in my garage last summer and i replaced it. Well, i think there is two oil sensors there. The lower one being the dummy light switch(mine was leaking) and the upper one being the oil pressure sensor.
Kind of a pain to get the old one out and I was planning on replacing the oil pressure sensor as well but couldnt get to it....
webironmongery
