Okay, I just got done draining the radiator and it runs hot...read..help.
Qualitywires.com
Louisville, KY
I just go done draining the radiator on my 1994 rt/10. I filled it back up with about 60 antifreeze/ 40 water. I burped the rad with the upper hose by squeezing it. Did this several times when the car cooled down. I also installed a flush kit using the upper heater hose. I installed one of those black T with a cap on top.
My car use to run between 185-195 degrees..well now it seems to run at 200 degrees...plus hotter.
Should I use more water than antifreeze? or what's wrong here? Any help would be appreciated.
luc
Paso Robles CA
I think that your problem is due to the 60% antifreeze.
Antifreeze doesn't cool as well than water,or if you prefer the heat transfer rate is lower with antifreeze.
Factory fill is almost always 50%.
You can either drain your cooling system and start all over again or calculate how much you need to remove to get to the 50% with adding 100% water.
You should also add a bottle of Water Wetter,it is usually good for 5 to 10 degree.
Luc.
webironmongery
