Positioning A Viper On A Two Post Lift
PIT VPR
Fair Oaks Ranch, TX
Looking for suggestions on how to get my Viper on a twp post lift. The side sills are too low to slide the arms under the car. The Dodge manual suggests driving the car up on wooden blocks, but I have visions of ejecting the blocks out of the rear of the garage as I try. Of course, I could use a floor jack to raise the front and rear, but I was hoping someone had a more creative solution. Any suggestions?
Performin Norman
Lee's Summit, MO, US
You really don't need blocks of wood, just some 2 by 10s. I thought about this for a long time when I was going to buy a 2 poster. I ended up buying a 4 post unit though. You may only need to raise the car an inch or so.
GTS Bruce
Orchard Park,NY,USA
My dealer and Viper tech use a 2 post all the time.Drive car into position.Jack slightly front/rear.Slide arms under front/rear.Off is easier as the suspension stays extended.Drop arms,slide out arms,drive away. Bruce
Diablo Joe
Lakeland,Fl
I use a couple pieces of 2x4 to drive on before I jack.It lifts the car enough for a floor jack(or lift)
Joe
FRANK
Somewhere in southern NJ
It depends on the lift. I have a 9,000 lb Challenger and I use 2X10's underneath to slide arms under. The arms are very beefy and won't go under.
Mohawk and Rotary are the only 2 post lifts that will slide under without using boards that i know of. Mohawk is too expensive (about $5-7,000) and Rotary has flip up pads that I do not care for...
What was nice about Challenger is that it is very beefy especially the arms. Also you can lift vehicles symetrically and assymetrically. I feel very safe underneath it.
rlamorte
