RT/ED
Power Steering Fluid Magna-Pure In-Line Filter
Debris is a major cause of steering system failure. It travels via the fluid throughout the entire system, eroding and clogging various components and hoses, leading to expensive repairs. The new Magna-Pure In-Line filter can help prevent this contamination.All system from standard pump to rack and pinion will benefit from these filter.
- Fits All 3/8
You must be registered for see images" Hose Applications
- Patented By-Pass Filtration Technology
- Helps Reduce Contamination
- Hoses Not Included
- Install Filter In Return Hose
- Serviceable Magnetic Filter Element
- Sure Grip Barb Connections
- Durable High Grade Aluminum Construction
- Made In USA
