The Ultimate NA Gen II Viper is Going Up for Sale
Jack B
NE Ohio
I have been having a hard time making a decision to sell my Gen II. I just do not have enough time to dedicate to the Gen II since I bought the Gen V and the Gen II deserves better.
I will post the car in the classified next week on the three viper sites. The car runs excellent and early in 2013 it ran a 10.9 at 128 mph with a DA of 2500. This car is capable of a 10.5-10.6 sec ET on a cool day and at sea level. It has also done back-to-back 129 runs on a day with a 3000 DA. The Jeff Moray heads/cam is actually as streetable as a stock car.
The car comes with the SCT X2 tuner. It also has a full Innovate a/f set-up and logging system (DL32). In addition, it has the X2 A/f gauge in the oem voltmeter opening.
Currently the exhaust is catless and is 3" Balenger all the way, it is one of the best sounding NA vipers you will hear, it is loud. The good part is, the car comes with the oem exhaust/cats, therefore, if you do not like loud, you can change it back.
Here are the particulars:
1997 GTS - 25,000 Miles Red/White Stripes
Royal Purple HPS used since 10,000 miles
ENGINE
Jeff Morey Stage III Heads and Cam - 10.5:1 Compression/Bee Hive Springs/Larger Valves
Head Studs -ARP Kit
Balanger Headers and Exhaust - Catless - Car also comes with the Oem take-offs (headers, cats & exhaust)
Accufab Throttle Bodies (new 2012) - Intake ported to throttle bodies
Stage 8 Locking Header Bolts
T&D Rockers -Matched/machined to Head Stands
Trick Flow Chrome Moly Push Rods -
Fuel Rail -
50 LB Injectors - Injectors Balanced by Tony Armour
Boost-A-Pump
180 Degree Thermostat
Accusump (3 qt) - Ignition operated with shut-off switch
2000 Model Year 10 Qt Oil Pan - Hinged Trap door and Custom Windage Scrappers
ACR Oil Filter Adapter
Custom Cold Air Box
Roe Red Silicone hoses with Bleeder
Catch Can with PVC rerouted to can
Roe Breather on Valve Cover
Roe Cold Air Inlet at Chin
Underdrive Pulley
Burping Tee at Heater Box
Custom Spark Plug Wire Looms
Red Silicon Coolant Hoses
Drive Train
John Donato built transmission
SVS Billet Shifter
Billet Cross Member
Spec Petal Type Clutch
Spare Flywheel
Spare Spec Clutch
Unitrax Half Shafts
Roe Clutch Pedal and Roe Travel Reducer
Drive Shaft Loop
Aluminum Belly Pan - OEM pan also comes with car
Archer Anti-Toe Brackets- Only fits on one side due to 998 recall
Half Shaft loops
Line Lock
Tuning
SCT Pro Racer X2 Tuner - Multiple tunes go with car/X2 tuner allows full tuning
Innovate A/F gauge and logger (DL32) -A/F Gauge is in OEM Voltmeter Position (Oem gauge comes w/car) The logger is set up for A/F, Throttle, RPM, Fuel Pressure and Vacuum
Two Position Pillar Gauge Pod - Voltmeter and Fuel Pressure
Raptor Shift Light
CHASSIS
Race Alignment at 25,000 miles
CCW Classic Wheels w/PS2
BTR Roll Bar - Red powder coat
Woodhouse Adjustable Sway Bar
Fire Suppression for Engine Bay
Toe Eyes Front/Rear
Power Steering Captive Cover/Breather
Tom's Rear Brake Kit and Proportioning Valve
Slotted front rotors/aluminum hats
New Rear Rotors
Track brake pads
Differential Pinion Arms Poly Bushings
INTERIOR
Carbon Fiber Center Console
Carbon Fiber Radio/AC Surround (Hydro Dip)
Dash Painted Black Satin (professionally) - Original dash was stripped, sanded, primed and painted
2008 SRT Race Seats by Verzano - OEM seats also go with car
5 Point Seat Belts - Drivers and Passenger
Custom Sneaky Pete Floor Mats
MGW Short Shifter/Grip
MGW Radio/AC Knobs
MGW Gas Cap/Door
MGW Console Compartment w/Cup Holder
MGW Ash Tray
MGW Lighter
MGW License Plate Holder
Chrome Gauge Surrounds
Black/Red Shift Boot and E-Brake Boot - By Redline
Air Flight Aluminum Pedals
Air Flight Sill Kick Plates
Sony Radio & Explod Speaker System - OEM radio comes w/car
Miscellaneous
Painted Viper Logo Hood Pad
Extra remote/key fob
Chrome OEM GTS Emblems Side/Rear
Full 998 Recall Done
Optima Red Top Battery
New Drivers Door Spring - 2012
Rear Glass - New Gas Shocks 2010
Take-Off Parts that Come with Car
Original OEM Seats
Original Radio
Original Exhaust, Headers and Cats
Original OEM Air Box
Original OEM Voltmeter
Original OEM Belly Pan
Original Shifter Console
Orininal OEM oil Pan
Spare Flywheel
Spare Spec Clutch
OEM Shift Knob
OEM injectors
OEM Rockers/push rods
Available Options
CCW Wheels with HoosierA6 Autocross/track tires
Double adjustable Alden front shocks/springs
ViperJohn
Maryland
Sad to see you letting her go. You invested so much time and energy getting it just right. Best of luck with sale.
J
Jack B
NE Ohio
I was at the point that there was not much left to do. Personally, half the fun is watching the car's personality change as you add the mods. I am at the bottom of the pyramid with my GenV, however, I did spent the whole winter working on it. That car is ready to go, but, I am still snowed in.
Fatboy 18
Surrey, United Kingdom
So what's it worth in the real market :( One thing for sure I don't think you will get back your investment :( You will have some people out there that will step away from a car that has been driven hard.
Saying that, I just wish I had more space and money :D
Good luck with your sale :)
martyb
IL
Jack,
Tried to send you a PM, your inbox is full. If you have a chance give me a call in regards to your car.
Marty. 224 587 0718
J
Jack B
NE Ohio
In Ohio the Density Altitude (DA) is usually in the 2500-3500 area. I took it to the dragstrip last year right before I received my G5, It has consistently trapped 127-129 in 2011 and 2012. If the car was on the coast in cool weather it would be trapping 132-134. The last ET it pulled was a 10.91 and the 60' was not that great. The car has a 10.5 in it with a low DA.
You probably can work those numbers backwards and it will probably show 575-600 rwhp, which is approx 675 flywheel hp. It took me a while, but, thr SCT tune is probably as good as it can get. What is nice, the engine runs smoother than when it was stock. The car pulls off the line all the way to 6000. It goes through the traps at about 5700 and it is still pulling hard, fourth gear is a killer. If I could find a way to drop a couple degrees timing over 5000 (just in 4th gear) I could probably pickup another 1/10.
Maybe I missed it but how much power does the car make?
J
Jack B
NE Ohio
There seems to be an error in the number of PM's retained and I cannot get ito go away.. Give me a call any time. My cell is 440 622 1100 and my email is jbene at electro-specialties.com.
I am probably going to post it this week. I wanted to post it when the weather broke, unfortunately that just happened.
Jack,
Marty. 224 587 0718
jpolen21
