Power steering is too tight.
AviP
New Canaan, CT
My GTS' power steering feels non-existant AT TIMES. But that's the keyword: AT TIMES. I have changed the fluid and the problem has not gone away. This has existed for a long time now but of late, it's gotten really bad. It's worse in slow speed turns (parking lots, exit ramps) but now it's been showing up at highway speeds too.
I want to work on it myself. How do I diagnose what might be failing and how hard is it to do a complete power steering system removal, cleanup, inspection and installation. What are the aftermarket options?
Dom426h
DE
interesting, i wannder how much a new PS pump costs?
Have you talked to the wizard about it?
Likely culprit is the PS pump / pulley ..........or maybe the Rack, unlikely.
Is the OE plastic pulley buggered? Does the belt make noise or show signs of fray / edge wear?
be 100% certain to replace the plastic pulley and cast bracket with billet. (from Dave's Big Brakes/PartsRack please) Under $200 for BOTH.
99 R/T 10
Enterprise, AL USA
P/S pulley is a known issue. Likey that is your problem. If you try to move it back and forth, look at the base where it attaches to the Pump shaft. Any movement means it has failed. Fairly easy fix, just not a fast fix.
AZTVR
Chandler AZ
I thought that power steering pulley failures were catastrophic, belt throwing affairs ? I can't picture it failing and just slipping on the shaft after seeing the cracks that were developing in mine.
However, if that is your issue, get it fixed now before it gets worse.
A
AviP
New Canaan, CT
Thanks for the ideas. I'll start this little project when the temps get into the 50s. Will keep you posted.
SE7EN
Any update on your power steering issue? I am having the exact same problem. Pulley seems fine but power steering is almost non existant??
bluesrt
my crysle ball says a rack, or a pump, or something else--- or a rack---
George Farris
Lipan, TX USA
Have the same problem.
Marked the pulley and shaft - no movement.
Right now, focusing on PS Pump - new is $550 ... YIKES!!
luc
Paso Robles CA
What about less than $100?
</SPAN> Related Parts2000 DODGE VIPER GTS 8.0L 7990cc 488cid V10 FI (E) OHV : Steering : Power Steering PumpPriceCoreTotal
ATSCO Part # 6240
{REMAN PUMP W/O RES}
w/o Reservoir (Only 1 Remaining)
$60.79$16.00$76.79
A-1 CARDONE Part # 20771
{w/o Reservoir; Reman. Does Not Include Reservoir Cap}
$46.79
George Farris
Lipan, TX USA
That may work, but it looks like a Gen 1 pump which will not work on a Gen II.
Will investigate.
