Problems starting my 93 RT/10
mcb48
I am having problems starting my 93 Viper RT/10. I can turn the key to the start position, but the engine won't turn over. I need to pump the clutch a few times and then eventually she will fire right up. Any ideas on what I need to go after near the clutch pedal?
Dan Cragin
LA, CA
Most likely the clutch pedal shaft and bushings are worn, this does not allow the the neutral swith to engage. I can get these parts for you.
jasontiff
Austin
On my drive back from first purchasing my 1993, my brother and I were stranded at a gas station for a half hour figuring that out. We eventually stomped the clutch to the floorboard and it'd start. I was told later it was the bushings and had the whole clutch replaced.
RAYSIR
Salem, OR
'Say What??' change the clutch because the Clutch/neutral switch or pedal bushings were worn out? What am I missing here? How do the 2 conneect?:confused:
RTTTTed
The switch can be adjusted. If there's no screw type adjustment bend the metal plate or add a spacer, then order bushing and replace them.
Ted
jasontiff
Austin
I didn't change the clutch BECAUSE of the worn bushings...it was about to go anyway. When they were in there, I told them about my starting problem, they investigated and confirmed.
M
mcb48
Sounds like a plan. I'll investigate it this weekend.
techanvi
