Push rods: Solid or with holes?
TorQ Junkie
central, il
When installing rockers (T&D/Mopar 1.7), are solid push rods used or the ones with the hole at the tip?
WESTCOAST JASON
Temecula, CA
They are hollow just like stock. (holes in both ends for oil flow) Be sure to use a pushrod length checker and order a new set of pushrods for the correct setup. It is worth the $180 or so a full set will cost. I can get you chromoly heat treated ones at any length sent out same day for you.
ctrengine
