orlandov10
- Joined
- Aug 2, 2005
- Posts
- 173
- Reaction score
- 0
I recently installed my nitrous and propane BTR kit, this kit was purchased from a local Viper owner who had it on his GTS for a couple of years, and before everyone tells me to talk to Tom Welch I've tried calling and emailing with no response, so I'll leave it at that.
My car is a 1999 GTS with Roe Blower, 8#, SVS headers, 3" Borla, no cats, Roe **** injection. We are maxing out my fuel pump and injectors at 602RWHP and 658RWTQ, hence the reason for doing the propane / nitrous.
I recieved one of BTR's older kits with an elaborate harness and Holley Viper fuel enrichment box deigned for a 92-95 GenI dry system from Holley, I was told by the previous owner that this box was removed as they could never get it to work correct, he let me know the system was changed over to a regular micro switch activation, however the box was still in the harness. Simply put I removed this harness and made my own, the system is hooked up just like any NOS wet kit now, and it triggers off of a micro switch, the only difference is I have a line running from my propane tank to the fuel solenoid instead of pulling fuel from the fuel system.
A few questions:
What size jets are some of you running that are using nitrous / propane only? I'm not using BTR's additional gasoline injection, I've read most are using a 52 nitrous and a 40 fuel, but I've also read a 52 nitrous and a 30 fuel so there is quite a big difference on the propane side.
What pressure do you keep your propane bottles at? MIN and MAX? right now my pressure is at 132PSI on a partially used bottle.
Does anyone regulate their propane pressure? I was thinking about getting a regualtor and keeping it at 90psi or so, how about a heater does anyone use a heater on the propane bottle to keep the pressure high?
A few questions:
