iron
Anyone know of a way?
Someone on here a while ago had devised his own fabrication.
I checked auto parts stores, no dice (so far anyway). I want to be able to take positive cable off terminal in a raise of a small lever, or the like.
Picture the nut assembly at present, but instead with a small lever (or some other way) ... vs simply a nut, to more quickly disconnect than loosening that nut (in being able to take that cable off).
Something that tightens as you put the lever in a certain position. Kinda like a bicycle tire pump, when you flick the new style ones down into position (after putting hose over the valve) it clamps the pump hose's end tightly onto the tire valve.
Thanks for anyone that knows of such a piece (broadly sold).
