race allignment question
SNAKE BITE
Belvidere, Illinois
Gen 1 with eibachs
current allignment:
Front -1.5 camber & 6 deg. caster
Rear -1.25 camber & 6 deg. caster
toe a little in from stock F&R
Question:
1. Should I remove sport shims for road course
2. Should I remove sport shims for autocross
This would change front camber to -2.5
Dom426h
DE
Question:
Prob not necessary on street tires, but you could go for alittle more camber. My street tires wear nice on the track at 1.7-1.8. Before aligning I took my shim out and replaced it with one half the thickness so if i want to up the camber by 0.5 i can on the fly. Mark your tires and see how they are wearing after each session.
Is she pushing/plowing(understeering)? If yes, up the front camber.
What tires are you running? Triple the REAR factory toe setting.
+1 for autocross.
Im fine with factory setting for roadcourse though. Anyone else use more rear toe on the track?
