Highlighted posts from Thursday, Jun. 17, 2021
  • Thread starter Top stories on Viper Club
  • Start date
T
Guest
Click here to view on the web
Highlighted posts
June 15, 2021 * 8 posts * 431 views
Chad Spackman said: Happened to talk with my viper tech last night. Referring once again to this: [link] The gen 2 has a "dual field" type A oval connector. One of the pins on that oval connector ... Read more >>
June 15, 2021 * 7 posts * 569 views
MoparMap said: Moving the seat forward and reclining it was the next thing I thought about as well (kssssnake beat me to it). That should help a little for those with shorter legs and longer ... Read more >>
June 14, 2021 * 2 posts * 189 views
FL2010ACR said: [image] Not the wheel you are showing in your post, but I have both original OEM rear wheels (black) taken off a 2010 ACR with only 30 miles on the car when they were removed. ... Read more >>
June 14, 2021 * 1 post * 54 views
SteveB said: Before I jumped into diagnosis, I figured I'd ask the audience if this is a common issue. While autocrossing my 93 RT/10 for the first time yesterday, I noticed a fuel smell. I ... Read more >>
June 15, 2021 * 1 post * 21 views
JWVIPER said: All OEM original off 95 Viper Ash Tray Cigarette Lighter 3 Dash Knobs for AC Fans etc Original Shifter Knob Oil Cap filler for engine $100 for all $15 flat rate shipping Contact ... Read more >>
June 15, 2021 * 4 posts * 578 views
Peter Kater said: Hello guys, I went with the delay timer (ELK 960) solution. It "kinda" works, which means it start from scratch, but provided you get a good 5 to 6 seconds fuel primering time. ... Read more >>
June 14, 2021 * 15 posts * 2,188 views
Kevin M Melisz said: I went with the 2.5" not 3", after speaking with Lou Belanger, 2.5" actually gives you better performance and a better sound. Yes 3" is louder but at cruising speeds it will be ... Read more >>
Continue reading...
Similar threads
T
Replies
Views
38K
T
T
Replies
Views
38K
T
T
Replies
Views
38K
T
T
Replies
Views
38K
T
T
Replies
Views
37K
T
Tombala
