Removing imperfections from Clearbra . .
rcl4668
Oregon, USA
For you professional or amateur detailers, what do you use to polish and remove scratches/surface imperfections from Clearbra-type film (Xpel, Vincashield etc.)? My Vincashield installer recommended Plexus for polishing and it works fairly well to polish when there are minor scratches. I was at an autocross and I believe one of the cones left a scuff on the clearbra. Is this buffable/removable and if so how?
I have already tried polishes such as 3M Imperial Hand glaze which reduced the scuffs a bit but not substantially. How do the pros detail clearbra material?
Thanks for any help you can provide.
/Rich
R
rcl4668
Oregon, USA
PlastX™ Clear Plastic Cleaner & Polish G12310 Product Information
Use foam pad and several applications :2tu:
If its too deep you might need to get it replaced. This stuff helps with lots of scuffs I have had. It has diminishing abrasives that break down as you polish. Thats why it might take several applications.
Clear Plastic Detailing - Car Care Forums: Meguiar's Online
Newport --
Thanks. I actually bought some PlastX andtried it. While it did make the surroundinf areas of the clearbra shinier, it did not really have an effect on the smudged areas.
/Rich
PaViper
You can use rubbing alcohol to remove fine scratches and marks
potterb4
