Removing sport pad?
Red94Roadster
Michigan
I need to remove the sport pad on my 1994 RT/10 to adjust my new Autoform hard top. What tools do I need to remove the pad? It was hard to see under the pad, so I don't know if the bolts require a wrench, allen, or other to remove.
sdaddy
Jacksonville, FL
If I remember correctly, here are four bolts and two studs for mounting the sport pad. The studs are notched for a regular screwdriver.
JiPi
Geneva, Switzerland
Just use a regular wrench.
Or better a ratcheting wrench, you will be done in less than a minute.
Don't remember the exact size (12mm I believe).
Don't need to unscrew the bolts completely, but just enough to be able to slide the sport pad out.
Randy
Earth?
1/2: ratcheting wrench works great, but the problem is getting the wrench back out of the hole after backing the bolt off. Often, you have to just use an open-end wrench, due to this space limitation... 5 minutes versus 10 minutes. :cool:
General Jackson
