Removing Swirls
Obsidian
Morris County, NJ
While I recognize this topic has been discussed a few times, I want to ask it again since I want to consider a few options. How do I remove swirls from my Viper (I have sapphire blue):
1. Can it be done without power tools?
2. Can it be put in the hands of a detailer?
3. If power tools are the way to go, what is the best tools and products to use?
Thanks!
plumcrazy
ALL OVER
cant really be done without power tools but id ask it in the detailing section maybe for more help
jojogts
I have a black silver stripes gts. Had the same problem I use 3m products swirl remover then 3M fine swirl remover bar none the best I have ever used or seen. Use a variable speed buffer with the correct foam pads you will be very happy.
RobZilla
Jacksonville, FL USA
There are several topic around the forum on this topic. Do a search. I know there is one titles "For those with black cars"
The best tool around is the Porter Cable 7924 buffer.
:usa:
