Removing tranny
omegac1
Baltimore Maryland
I am in process of replacing leaking clutch slave in my 1995. I have all 8 bolts off from the tranny to bell housing and a jack under the oil pan and tranny jack under the tranny. I can not get the tranny to "slide out". If I wiggle the tranny from the drive shaft end, the whole engine wiggles but I can not get the tranny freed up. There is not any crack between the tranny and bell housing to get a screw driver in etc. Is there some trick here...some pry point I can back the tranny off with??
MADMAX
UK
Camfab
SoCal
Garron
The dowels can seize, if you have all the bolts wiggle the transmission.
bluesrt
Get back by the tailshaft and grab it and shake the hell otta it up and down and back and forth..man handle it. ..keep doin that and it will pop loose i promise you.
jdeft1
Metropolis
Anybody ever pull a viper tranny without a lift, using jack stands?? Can it be done?
RapidTransit
Concord,Ca
I did it using stands, but only to change the clutch and slave. The jack I used for the trans wouldn't go down far enough to remove it alltogther.
MADMAX
UK
Yeh - I've pulled my tranny a couple of times from axle stands.
I needed to use heavier duty stands though, to jack the car up higher.
These are 6 ton stands and give good stability with enough height.
And I used a motorcycle scissor lift to lower the tranny out of the tunnel.
jdeft1
Metropolis
Looks do-able. So far, after many years of ownership, I haven't had the need to pull the tranny. No clutch or slave work either (knock-on-wood) on my '94 but with each new tranny thread I wonder how I'd handle it with no lift. My day will come. Thanks for the pics guys.
Jack B
NE Ohio
It is an awkward 135 lbs and it does not go in straight because of the knob/protrusion on the tranny's passenger side. If you are on lift with a good tranny jack it is not bad, on the ground it is a chore.
If you are changing the clutch, the line-up dowel that comes with the new clutch is way too sloppy, that can compromise getting the trans back in. After several in-outs I realized the tool sucked and made a clutch alignment tool that truly centers the disk, that helps the trans re-install.
xeng yang
