KenH
Replacing valve springs and retainers
I am curious if anyone bothers to replace the stock springs and retainers when upgrading to 1.7 RRs?
You are suppose to be able to do this with the heads on the engine using compressed air. I'm just wondering if it there is much benefit in doing it with a stock cam. You could reduce the valvetrain weight some and there may be some benefit in increasing the spring pressure a bit to help the engine pull strong to redline.
My engine has 40K on it, so although it pulls hard right to redline, it might benefit from freshening the valve springs.
As a secondary thought, the SCT allows you to increase the rev limiter. Anyone know if it is safe to increase the redline a bit on these engines?
--- Ken
--- Ken
