Reverse Gear Hard to Engage and Keeps Popping Out
HPmopars
VOA
Check your trans mount, if it is still stock it may be broken. Also check engine mounts while you are at it.
H@rleyguy
Minesota
I will give those a look on my 95 R/T, was there an issue once upon a time with a shim on the transmission cross member? I may be mistaken but I though I remember something about that.
klamathpro
Detroit
It's likely a bad reverse lockout solenoid. Easy replacement, though you have to undo the 2000 bolts holding the pan under the trans.
rlamorte
