ChrisGTS
Today, Achilles99 and I bled the brakes on my 2002 GTS in preparation for an upcoming track event. I received my Motive Products Power Bleeder (www.motiveproducts.com), and we used it for the first time today. I thought I would post my impressions.
First off, it is extremely easy to use. We used the universal adapter and it fit with no problems.
It is also a lot more efficient than pumping the pedal. Since there is a tank feeding new fluid into the reservoir, you don't have to worry about watching the fluid level as you would using the pedal-pumping method. Once you have the Power Bleeder pressurized, you just loosen the bleed screw and the old stuff comes out. We bled all four lines, twice each for good measure, in just a few minutes.
Anyway, I found it easy to use and effective, so I'd recommend it.
