Roe Crank Case Vent
agentf1
Phila Suburbs
Are these worth while/needed on a stock GTS? I can see on a SuperCharged car but am wondering how much they help on a stock car. Do you have one and do you feel it helps the car run any better.
Here is what the web site says.
Oil pressure and ventilation is very important when it comes to the performance and life of your engine. Our breather assembly screws right into the oil cap location on the valve cover and provides superior ventilation over the factory setup, greatly reducing the possibility of oil seepage, gasket failure and leaks.
http://www.roeracing.com/ProductCart/pc/viewPrd.asp?idcategory=6&idproduct=245#details
RTTTTed
If you like stock, leave it. If you like mods, do it. On a stocker it's very minor and probably not worth the effort, unless you want to do it. It does make a difference on a supercharged or Turbo'd engine and almost a necessity for them. There's really not a performance gain.
Ted
jpolen21
