ROE install. Car won't start. Need help ASAP
JiPi
Geneva, Switzerland
Hi,
We just finished to install a Roe SC on a 2002 GTS.
But the car doesn't start.
We have double checked everything with no luck.
The VEC showed the green led when the power is on
We have no spark at the plugs
We have the instructions but not the wiring diagram, can anyone post it ASAP please ?
Just a few questions
On the harness going to the PCM one grey wire is unused, is that normal?
We have disconnected the two big connectors C104 at the back of the engine at the drivers side and reconnected them with the two connectors from the VEC. Is it normal that the two stock connectors remaine unpluged??
We have tryed to call Roe with no luck.
We really need your help ASAP
Thanks in advance
J
JiPi
Geneva, Switzerland
I already talked to Chuck. He has a meeting starting right now but took time to point out a few things.
Didn't want to bother him too much, but he told me I really need to get the VEC wiring diagram.
RTTTTed
If you left the connector driver's side beside the pwr str pulley the injectors won't work properly. You remove 1 wire and connect it throught the Vec with the vec wire in the connector (if I remember correctly). With that stock connector disconnected I got 2 gallons to the mile.
The rear connector is for the injector driver's box and the vec harness connects between the stock connectors. No connectors unpluged.
Ted
J
JiPi
Geneva, Switzerland
Thanks for your answers.
Problem solved!
I did reached Sean and he pointed out what we did wrong (bad wiring at the coil pack connector).
The car fired up right away.
Test driving it tomorrow :)
Roe setup looks awesome and he is first class in helping.:2tu: :usa:
RTTTTed
You'd think that Sean should take a day off once in a while?
Glad you got it figured. Now comes the 'fun' parts. Driving and tuning!
If it 'pings' or has any issues baby it until it gets tuned properly. Better safe than sorry. Swiss, eh?
Ted
J
JiPi
Geneva, Switzerland
Here is the beauty!
Thanks guys.:2tu:
The car is unfortunately not mine...
Belongs to a French guy.
Mpcc
