JimT 99RT
Cats are welded, S/C is in... Life is good. Pulls great after 2500rpm, power is smooth and the car runs great. Going up the on-ramp you hit 110mph before you even know it. Car sounds great. Nice package everything was labeled and laid out great. It was not exactly a two-day job for me, but then I have to jack with everything. The 999 recall makes getting to the crankshaft bolt quite a chore. I ordered the pinning kit but I didn't use it. It would have taken quite a bit to try and get a drill in there and it would have taken an impact wrench to get the bolt out, I managed to get a torque wrench on it and made sure it was at 250ft lbs of torque. To get the bolt out and drilled would have meant taking off a lot more parts than I wanted to mess with, and as tight as the bolt was I'm not to worried about it. I'll just make it a point to recheck it occasionally. The only trouble I had was disconnecting the damn fuel line. I ruined the fuel line getting the manifold connector off, I yanked a little to hard and kinked the hard line. For now I put in a steal braded fuel line and have a new one on order.
Thanks Sean one very satisfied customer!!!
... Hell if I can put the thing in anyone can.
Polished Roe S/C @ 7Psi
50lb injectors
70mm Throttle bodies
Roe modified air box
3" Smooth tubes
High Flow Cats
50lb injectors
3" Smooth tubes
High Flow Cats
