Hi Kevin,
If you run a 7 psi pulley, you (or I) could write a program to keep the timing down to about 18 degrees advance total when running 91 octane. When you put in higher octane fuel to mix, or an octane booster, you can slide in a higher timing program card, running 22 degrees advance total. With 100 octane, you can typically run about 28-29 degrees total advance. Let me know if you want me to help you write or e-mail you a program.
Regards,
Sean
