Roy
I was on a nice cruise today with the sun on my head when the 92 Viper just died all of a sudden, uit felt like it was out of gas, but I had just filled her up!
So I thought it had something to do with the pump or battery.
Checked the battery, nothing, but than in the trunk I saw a relais halfway out of its socket, pushed it back in and thought, it can't be this easy, but let's give it a try.
It worked fine once again and at home I tried to pull the relay, found out it put the pump out.
Thought I would share the experience in case someone else has the same problem and is looking for a fix. gonna put a ty rap on the relais so it stays there were it should.
Not sure if it's normal for this relais to be there, but I'm glad I found it either way.
