Servicing cost, is this about right??
Scott5ppg
Pensacola, FL
I called two local dealers to get a quote and appointment info to service my Viper. One dealer said $600.00 the other said:
Flushing the coolant $125
Changing oil and filter $ 69
Gear box oil $125
Rear end oil $110
Lube chassis (free with oil)
New plugs $195
Total: $514
This about right?
Scott
Pensacola, FL :usa:
Steve 00RT/10
Michigan
Oil/filter change labor time....15-20 minutes
Rear end and tranny fluid change labor time...1.5 hours tops to do both
Plugs labor time...30-45 minutes $2 to $3 bucks a piece for OEM
Steve
Cape Coral, FL
Steve
Dont forget how expensive the fluids are for these cars... the above prices included fluids, they are not making much at all on labor.
I do concur though, plugs should be around 130-150 tops. Oil change is low, 80-100+ is typical for a dealer.
NoRice
Chatsworth CA
Gear box oil $125
Rear end oil $110
New plugs $195
Total: $514
This about right?
Scott
Pensacola, FL :usa:
I bet they didn't figure it to be synthetic or how many quarts it was going to take correctly. However, if you can get them to stick to that $514 it works out as the plug change is high, so it equals out the lower oil change price. I pay one hour labor plus plugs for my plug change.
Steve 00RT/10
Michigan
Steve
Yes, I know the OEM fluids are expensive. That's why I was only trying to show that the labor for the oil, tranny, and rear end is about 1.5 hours total. The total cost for the oil fluids I use is $175. All synthetic. The 0W-30 motor oil is actually quite a bit more than Mobil 1. The garage I use charged me $75 dollars this past September to change these fluids out. $250 total. I guess my point is that changing these fluids on a Viper is no different than any other car. Any good lube place or garage with a lift and people you know and trust can do it. Of course I am there with the car and monitoring the progress closely. The place I go to always lets me pitch in if I want.
Steve
Mopar488
The rear end oil is different from most cars. It will not drain since there is not a drain plug. A Viper tech told me it would take all day to change the fluid since he would have to take the rear end out at $70/hour to change the fluid. I asked him why he could not pump it out. He finally agreed and I helped him with a jerry rigged fuel pump and a battery charger and we pumped it out. If only I had a lift. I will do it myself on jack stands next time.
V10SpeedLuvr
Thats one crappy (or crooked) Viper tech!
