Should I have to replace the flywheel when I replace my clutch...
klamathpro
Detroit
Well, if I were you, I would get a lightened flywheel. Roe says it's the best N/A upgrade you can do for the money that is very noticable.
plumcrazy
ALL OVER
i asked chuck tator and he told me if it wasnt cracked, to just scuff it up and re use it. and i did and had no problems
CROM
Fairfax, VA
What Plum said. Chuck recommended cleaning it up with some emory cloth/steel wool.
He also did not recommend a lightweight flywheel.
99 R/T 10
Enterprise, AL USA
The Aluminum flywheel upgrade is a personal choice. It does help the engine spin up fast(less weight, 17lbs), but if you have a car with out-of sync TB's it will exacerbate(sp) the bucking problem you may be feeling. I personally like the Aluminum flywheel for a stock car or one that has bolt-ons, but if you're pushing over 600 RWHP, I don't think it matters. My $.02.
GTSnake
Motor City
The lightweight flywheel was the first mod I ever made. Even before smooth tubes.
got one
Castle Rock
Also, do you have upgraded gears? I have heard some folks complain about the two being together.
R
Richard H. Vitale
Dallas, Texas
Plenty of mods, but no upgraded gears... that Im aware of. I believe that Im the 3rd owner, consequently, not 100% sure what was done before my purchasing.
xeng yang
