SweetRed04
I almost have my cruise installed, but before trying it out a question occurred to me.
Do you adjust the actuator cable to work when the pedals are furthest forward? I set mine in the pedals rearward position and think I need to readjust to the furthest forward. That is where I set them driving anyway.
If not set in the furthest forward position the 100 mm of pedal travel would appear to rip the cable out of the control unit if you set it up in the furthest rearward position. It would appear that the cruise won't work in all closer positions because you will run out of cable travel.
Any comments on this apparent problem?
