Snake oyl Trunk release anyone have it????
Quantico, VA
I installed one in my GTS. Button goes wherever you want it, there is a solenoid operated actuator that replaces the OEM actuator. You lose nothing...key works normally from outside....button works by pushing. NOT hard....but getting the wiring to the cubby is a PITA. Thats about it. :)
DEFINITE GOOD THING.....but expensive. I think I bought mine used for $99 somewhere.
RAYSIR
Salem, OR
On the GTS you can get a live feed real easy under the left B pillar (by Driver side window) There is B+ and ground there for interior lights I believe. I used this for my Valentine 1 detector and also fused it there. (make a note in your book for fuse locate). Not sure if RT has wiring in the overhead but should be a loom heading to rear behind the seats or by the Amp.
Quantico, VA
Cheers Mate
Where did you take your live feed from?????
I had the interior out to install the Autoform rollbar so I ran the hot lead up to the lighter.....figuring there was hardly any load there. Thing is....it is hot all the time so you could, feasibly, pop the glass while driving (by accident, of course). :)
I'm sure you could wire it differently...or change the button to some spring-loaded toggle with a saftey cover.....etc....etc. :)
Eldon
Northern California, USA
Baz...... read on: http://forums.viperclub.org/showthread.php?t=601251 for some alternative views & suppliers.
Seeya Tues/Weds/Thurs...... Paul H (who should be up as owner, but enthusiast will do......for a week or 2 at least(hey, 1st post!)[/quote*
PKH2552, why not go for member rather than owner and be a real VCA participant.
Congrats on your 1st post.
Mpcc
