Chuck Greggs S Arizona ACR
Did the dealers scan for any trouble codes? You can check for codes by cycling the ignition switch to on-off-on-off-on, then count the number of times the check engine flashes, noting the pauses in between the flashes. For example, 5 flashes-pause-5 flashes = code 55(this is the code for end of test). I, or someone here will look up the code(if any)for you.
This problem sounds like a defective crankshaft(or camshaft)sensor, or the wiring shorting out. Also, could be a bad connection at the wire bundle located at the right front of the engine. If engine does not start, try moving the wire bundle around. I had these exact problems on a brand new 1994. The computer needs signals from the crank and cam sensors for the engine to start, or run.
It is possible that you could have a weak fuel pump, but that usually will not cause the engine to die. Typically, it would only be hard to start. You can usually cycle the ignition on and off a few times to get it to start.
Good luck,
Chuck G.
Good luck,
Chuck G.
