Stock tire milage?
DviperX
Louisiana
How many miles before your stock tires needed replacement? It appears my treads are good but the handling and spin out is horrible. I have 13,000 miles on them.
D
DviperX
Louisiana
I kind of figured that so I just purchased a new set of Pilots from Tire Rack. Front and back so hopefully that should solve my problems. Thanks for experiance:)
Randy
Earth?
As already mentioned, the age of the tires directly affects how hard the tires are, etc. New Sport Pilots are quite nice handling and gripping tires. However, old Sport Pilots (or any tire) typically don't grip well, and can be literally dangerous on a high-horsepower car. With that said, I bought my current '00 RT/10 in 2004 with 12k miles on what I assume are the original Sport Pilots. Its now got 28k miles on it, and the rears are down to the wear bars, and its already been a bit dicey at hard cornering or high throttle. Its also darting almost as bad as my old '95 RT with the original XGTZ's and 25k miles did. However, I've not experienced any push or understeer issues, which I would also expect with lessening front-end grip.
As such, I'm thinking about replacing all four tires, despite the fronts still showing a ways to go before the wear bars. I figure tires are cheaper to replace than bodywork if I should indeed lose it. :cool:
garolittle
Augusta, GA
I got about 19K miles of the orginal tires on my '01 RT/10. There were getting a little old so I replaced them even though I probably had another 5K miles left.
GR8_ASP
My experience is 12-15,000 miles or 5 to 6 heat cycles. Whichever occurs first. It is tough to have half tread life remaining when the heat cycles have resulted in tires with no grip.
DodgeViper01
Central New Jersey
I find that the average for the rear is around 15,000 and the front about 20,000 but there are expections to this rule. Ask CitySnake, 30K+ on original tires.
AviP
New Canaan, CT
Or me @ 23K. And I'm not at the tail end of the pack either. :D
V 10 MAFIA
I think City Snake has the record for original tires.
Purdue_Boiler_Viper
Indy
Anyone got any data on tire hardness / grip vs. age? I've only got 5k miles on my 01 GTS. Tons of tread left, but I can't find any clear data on when to replace "old" tires.
97 B/W GTS
Dallas, Texas
DViperX - Let me know how much better your traction gets with the new tires.
I too have the original tires. 10K on them. Traction *****. I know I need to replace mine...just curious on your experience when you get the new ones. Like "night and day", or just a little better, or...
Purdue_Boiler_Viper
Indy
It appears that there is little data on this. Bridgestone - Firestone just announced a 10 year max, but BFS’s bulletin says the company “is not aware of technical data that supports a specific tire service life”.
The following if from TireRack:
The British Rubber Manufacturers Association (BRMA) recommended practice issued June, 2001, states "BRMA members strongly recommend that unused tyres should not be put into service if they are over six years old and that all tyres should be replaced ten years from the date of their manufacture."
Environmental conditions like exposure to sunlight and coastal climates, as well as poor storage and infrequent use, accelerate the aging process. In ideal conditions, a tyre may have a life expectancy that exceeds ten years from its date of manufacture. However, such conditions are rare. Aging may not exhibit any external indications and, since there is no non-destructive test to assess the serviceability of a tyre, even an inspection carried out by a tyre expert may not reveal the extent of any deterioration."
More recently, The Japan Automobile Tire Manufacturers Association (JATMA) recommended practice issued May, 2005, states "customers are encouraged to have their vehicle tires promptly inspected after five years of use to determine if the tires can continue to be used (recommends spare tires be inspected as well). Furthermore, even when the tires look usable, it is recommended that all tires (including spare tires) that were made more than ten years ago be replaced with new tires. Additionally, because in some cases automobile makers—based on the characteristics of the relevant vehicle—stipulate in the owner's manual the timing of tire inspection and replacement. Please read and confirm the content of the owner's manual."
Several European vehicle manufacturers of high performance sports cars, coupes and sedans identify that "under no circumstances should tires older than 6 years be used" in their vehicle owner's manual. However, it should be noted that European recommendations must include driving conditions that include roads like the German Autobahn, which allows vehicles to be legally driven at their top speeds for extended periods of time.
While American driving conditions don't include the high-speed challenges of the German Autobahn, the U.S. divisions of DaimlerChrysler and Ford Motor Company joined their European colleagues in 2005 by recommending the tires installed as Original Equipment be replaced after six years of service. (General Motors declined to offer a recommendation until a more scientific analysis of driving conditions and tire aging could be completed).
It's common for The Tire Rack to receive new tires direct from the manufacturer that are three to six months old. Since we rotate our inventory, most of the tires we ship are less than a year old. There are some occasions where we work with a tire manufacturer to help them clear out their warehouses when they discontinue a tire line. While this clearance frequently uncovers some new tires that are several years old, these tires are offered at a significant discount and will most likely be worn out within their useful lifespan.
It is also important to note that the more aggressive the tires' tread compound, the shorter its life. DOT-legal competition tires would have the shortest shelf live before the aging process would begin to diminish their performance. Sometimes the tires that were just right at the end of this season will be too aged to be fully effective the next year. Max Performance and Ultra High Performance tires would be next, and so on down the line.
Our experience has been that when properly cared for, most street tires have a useful life of between six to ten years. And while part of that time is spent as the tire travels from the manufacturing plant to the manufacturer's warehouse, to the retailer and to you, the remainder is the time it spends on your vehicle.
Randy
Earth?
I've heard 5 years is the age you wanna scrap tires and get some new ones
I'd agree. My 6-year-old Sport Pilots are definitely losing grip, as evidenced by the increasing number of unintentional burn-outs and the back end trying to pass me under hard acceleration.
I also agree with the long posting about the more sticky tires having a shorter shelf life - I've got a set of Hoosier R3S03s (I think thats the number) that are about 4 years old and worthless - Last time on the track with the old R3's on the rear and a set of brand-new R4's on the front, and, I swear a new set of street tires would have had better grip than those old R3's on the rear. The R4's stuck like glue, but that didn't help very much with the back and trying to swing out on every turn.
ctrengine
