Hi,
I have a Borla cat-back exhaust and I tried loosening the forward section with the muffler (under the side sill). I loosened the clamps, but the pipe was stuck at both the downstream portion and the upstream portion towards the cat. Any hints on how to loosen them? Do I need to remove the downstream pipe(s) first?
Any hints on how to re-install the side sill easier? Both times I had it off, it took like 15 minutes to wrestle that thing on. I started lining up the forward section first.
Thanks,
Alex
Thanks,
Alex
