Stuck Thermostat?
96GTS
Dyess AFB, TX
I was washing the Viper today, and let it run while I dried it to charge up the battery a little. I got in it when I was finished and noticed the needle on the water temperature was at 250. I had never seen it get over 190, even at a track event, so I was concerned. After thinking about it, I didn't remember the fan ever kicking on. Does it sound like the thermostat is stuck shut , or could it be an issue with the fan?
96GTS
Dyess AFB, TX
Fan spins freely and the fuses aren't blown. I'll have to check the connector tomorrow.
Thanks.
dave6666
We'll assume obvious stuff like there's coolant in the system? And you did twist the dash knob to hot?
Seems strange that there's no heat at the heater - aka no hot coolant circulating - but no fan either.
96GTS
Dyess AFB, TX
It puked coolant for a little after I turned it off the first time, but I doubt it was more than a few pints. I had the knob set at cool to see if the fan came on with the A/C and then put it to warm to check the heat.
Neil - UK
ENGLAND
The fan blows, but no hot air.
no hot air, and a quickly rising temp guage = water pump failure
just changed mine after it failed, the plastic impeller was loose and wouldnt spin on the shaft
dont drive your car until its sorted, to long at 250 and youll swapping the engine as well !
dave6666
Why doesn't the radiator fan come on then? Even with the AC on?
WANTED
I was thinking the same thing, Water pump.
SNKVENOM
Does the Guage rise slowly to 250 or does it peg to 250 when you start? If it pegs it is the sending unit mounted on the front of the motor. $ 50 dollar fix. Parts at Dodge.
dave6666
The gauge rises slowly.
What about checking the heater for heat. Did you switch the right knob to "heat" when you did that? As I mentioned above, just turning the center temp knob all the way right will do nothing unless the selector is set to heater.
And I don't mean to challenge you on that simple point, but based on the way you worded it above, it made it sound like you just twisted the center temp knob to hot while still on AC. That won't give you heat.
dave6666
When I moved the knob to defrost heat did come out.
That suggests several things then.
-> You have coolant.
-> It is circulating. AKA water pump is functioning at least minimally.
Does the upper radiator hose get hot after the gauge reaches 220 or so? This would suggest the t-stat is open.
I'm still leaning toward the fan or some component of it. It's easy to get out. Put it on the bench and connect a battery to it. Or a battery charger. With the correct wiring diagram to assist. If I had a '96 manual I'd give you the pin outs on it.
xeng yang
