Steve,
We are an authorized T&D dealer and install them quite often. They really aren't that audible. If you have too much noticeable sound difference AFTER installing them, you may need to go back and check your valve lash. If you installed the shims provided with the set, you can inspect the inside of the valve covers to see if they are making contact with them.
Good Luck,
Doug
