Tall guys in a Viper GTSs please respond
00prowler
Vernon CT USA
If I add a 2 inch seat lowering kit will a 6'3 person fit in, and be able to drive the car comfortably..Thanks...Al
Detlef
Northern Colorado
I am 6'2" with a 1" lowering kit and I fit just fine. Only time I wish I were shorter is when I am driving into the sun with the visor turned down. That thing is so bulky. I also fit with a helmet on.
dave6666
6-4 210 and I use the 1" kit. My knee is against the headlight switch most of the time but ***, I'm in a Viper. Woohoo!
Plenty of head room as I can wear a ball cap but in the SRT I cannot.
ViperTony
Al, I just made and installed a 2" kit and gained 1.5" of knee clearance from the bolster and I feel short in the Viper now. I'm 6' and fat. So if it works for someone like me it should be OK for 6' 3". If you want to borrow one to try out let me know. - TP
00prowler
Vernon CT USA
Thanks for the responses TallBoyz Tony I dont recall you being fat last time I saw you!...Al:D
Martin
I'm 6'4" and with a 2" lowering kit, the car fits perfect. The only problem with the lowering kit is it limits who else can drive the car. Not a problem most times, but there have been a few instances where I would have rather let my g/f drive me home rather than take a cab and leave the car sitting on the street all night...
RTTTTed
Other concerns are torso height as compared to leg length. My body sits 6'4" while I have shorter legs. I sit closer to the steering wheel and tall. Made my own 1.5" seat lowering kit (as shown in Illustrated Upgrades) and although I fit before ... vision and comfort are much improved for me.
Ted
rt/10stew
Cambridge,Ontario
So is there more head room in a gts than in an rt/10? as I am 6'3" with a 1" drop seat but still find it too restrictive.
thanks Stew
harley56
Northern California
Depends on where your height is - torso or legs. I'm 6'3", with a 37" inseam. Lowering kit hurt as it moved the base of the seat further forward; however, I'm probably the exception.
ViperTony
Nope, my inseam is 32" and I had the same issue until I made my own 2" kit which puts seats as far back as possible and still maintains a 2" drop. I never understood why those kits push the seat forward so much when knee room for the tall is at a premium in the Viper. :dunno:
Tagoo
Boise, ID
I am 6'4" with a 35"-36" inseam. In my 2002 RT/10 I was really cramped. I had to use the 2" seat drop kit to be able to use a helmet with my top on. The bummer with the lowering your seat is that it drops you down so far it makes it kind of difficult to exit the car.
My 2000 GTS is much roomier. I fit in fine with the stock seat height. I think I have as much headroom in my GTS without a seat drop as I did in my RT/10 with the 2" drop.
Dom426h
DE
When my friend who is 6'9" gets asked by people, how do you fit in there?
He says: Look at it, its a Viper, how Couldnt i fit???
his head skims the headliner. if he had to tilt his head then i'd consider getting a lowering kit for the passenger side.
yes he plays B-Ball:)
NI-KA
Canton, Ohio
I am about to add a 2" fixed drop to my '06 coupe. I am 6'-2". However my wife, who has driven the car once is quite a bit shorter. I was hoping that someone out there might have a reasonable solution that would make up the difference to the seat. It is clear she will need some type of booster (clearly forward and then of course up 2")
I thought that there might be some type of cushion/booster used for pure race seats that might work.
Does anyone have any knowledge of anything like this?
