Throttle cable clip
Rheeder218
Harrison Twp MI
Does anyone know what the part number is for the little clip that holds the two throttle cables on top of the intake manifold. The clip holds the twp cables together, from bouncing all over. I accidently broke mine last night changing out the valve cover gaskets. Thanks for the help.
V
Venomiss
Guest
Do you have a picture of it by chance? Someone should be able to identify the part.
viperrt96
Indianapolis ,In
If you have a GenI and your looking for the push in double clip (holds throttle cables) that goes in the intake about center of the motor it is part # 5245 520
cookviper
