Tick Tick Tick!!!!
Izover4u
Chicago, IL
So today my car started ticking while in neutral :crazy2: I've read several posts on how vipers have noisy injectors and valves and that this noise is very common and normal. However my car never did it before and some dont at all so how much is it going to cost me to fix this annoying "tick":dunno: Have any of you guys fixed this "Tick"?
Venomiss
Guest
VCA members don't get the tick....:)
Call Chuck Tator and ask for ideas?
DavidSB
Santa Barbara
Does it go away when the engine warms up? If so, you may have an exhaust header crack where the gusset is welded to the tubes. The crack opens when cold and closes when hot.
I
Izover4u
Chicago, IL
Nope it seems its the opposite... The sound becomes apparent when the car is warmed up...
xjrguy
Oil or other lubrication issue?
Have you checked the dipstick lately?
Roadrunner
As strange as it might sound... are all the spark plugs tight? I once had a 4.0L jeep that was ticking and it was pressure escaping around one of the plugs that had loosened a bit. Don't torque em' hard, just look for any that might have gone loose.
And all of that only if the ticking is coming from the area near the headers / plugs.
I
Izover4u
Chicago, IL
I will give it a check this weekend thanks :2tu:
kennyhemi
Miami Fl
As well as a loose spark plug! a spark plug cable not seated properly either end will make arc/tick noise, also check for an exhast leak. sometimes they will sound like a tick; If it warms up and get worse it my be a lifter bleading down as oil thins out as temp rises.
I
Izover4u
Chicago, IL
Finally had the chance to take a look at the car today.. turns out it was a spark plug wire... Started the car last night, pop'd the hood and saw sparks from plug #1... I went out this morning to check out the spark plug and found the spark plug itself was not loose but the wire was faulty. The inner part of the wire came out and was stuck on the plug :(... So I need to buy new spark plug wires. Any suggestions? :2tu: Stock or after market?
Warfang
California, East Bay
You must be new here...
home
I
Izover4u
Chicago, IL
home
Thanks for the link:2tu: I may go this route...
Since only one wire failed do you think I should just run to the dealer and purchase one wire if they allow me too? Will I really see any benefit to these wires compared to stock?
Warfang
No man... AB's wires are the BEST. Not to mention the guy is a regular here and once a Viper owner (getting back into one soon I hope), and an upstanding businessman. He won't rest until you're happy.
On top of that, the quality of the wires are tops. Ask anyone here that has em.
No members online now.
JKGiant
