TIMING
622r109
liny
Hiow Do You Reset Timing On 05 Viper,my Car Blew 2 Pistons When # 6 Injector Stayed Open,i Know Computer Resets Timing, But What If Timing Jumped A Tooth. What Do You Do Toreset It. Thanks In Advance Gary
plumcrazy
ALL OVER
id call tator and ask him but i dont think there is much you can do without a VEC unit or something like it.
Racer Robbie
Guilford, CT-USA
If your Camshaft and Crankshaft are aligned and timed properly then that is your base timing. Other than that the ECM handles the timing advance curve on a factory stock engine. That is the beauty of the DC tune as Dan can remap the timing and fuel curves to your modifications.
Robbie
Joseph Dell
Atlanta, GA 30338
Um... you answered your own question. the #6 injector stayed open. that was the issue. timing doesn't jump a tooth. if it did (even if it was off 5 degrees) it wouldn't cause an N/A car to blow.
xeng yang
