Tire Pressure?
Dale.Volz
Gilbert, Arizona
A question for those of you with experience/knowledge in road racing a Viper: What tire pressures do you recommend cold and/or what do you hope for coming off the track?
I'm running a '96 GTS with 305/35 and 335/30 tires.
Thanx
rw99
Castro Valley, CA
Share a bit more on your setup and you'll get some good answers... tire brand/model, suspension setup details, etc.
Will this be HPDE-type driving?
Rich
2006red/whitecoupe
Summer in Minneapolis, Winter in Phoenix
IF you have't been on track before, put them at the manufacturers suggested inside driver door. If you have been on track before put them at manufacturers suggested inside driver door. Generally, you want to run the upper end of what the manufacturer suggests to reduce heat, the more round the tire, the less heat. Call John Archer if you want to get more complicated than that, he services NRRA cars including ACR, ACR-X, comp coupes, and daily drivers.
Dale.Volz
Dale.Volz
Gilbert, Arizona
Info as requested:
  • Toyo R-888 tires; 305/35 front and 335/30 rear
  • Lowered with Hyperco springs
  • JRZ adjustable racing shocks front & rear
  • Splitter in front; Autoform wing in rear
Thanks guys
Viper123456
