To use TPMS sensors or not
Jonne
Nutley, NJ
I'm getting new Nitto Invo tires for my 18/19 HRE wheels. Does it make any sense to swap the TPMS sensors from the runflats or just leave them out since the Nitto's are not runflats. I know I will get the "lowtire" text without the sensors, but do I get the constant "bling,bling" sound too? What you guys usually do?
:usa:
Luke@tirerack
I would say if possible use the sensors because if you have a problem it will allow you more time to bring the car to a stop which in turn could save a wheel from being damaged
:usa:
The chime dings ONCE......and LO TIRE indicates at the ODOMETER.
But as Luke says: You will KICK YOURSELF when a tire goes low, and you either LOSE CONTROL in a corner, or DAMAGE AN EXPENSIVE WHEEL with a flat.
MOVE THE SENSORS.... (Or get new ones programmed) HINT: they wont fit most HRE outers, gotta get inner brackets.
LATE EDIT: IF YOU DONT HAVE SENSORS, CHECK YOUR PRESSURES ON EVERY TANK OF GAS....or get those (leaky) Red/Green Indicator stems to alert you. Low Tire = Bad News.
ViperGeorge
Greenwood Village, CO
My .02 is that the darn things are a pain in the a$$. I've had to have mine serviced too many times to count. Hate the things. If the tires are low I'll know it but then again I check often.
WILDASP
Columbia, SC
Evey time I think TPMS has gotten better, I hear another story like this. I've never had a problem with one, but I know plenty of people who have. In any case, while I think the thing is useful as a backup warning system, I don't think it's a substitute for checking tire pressures regularly and often (no matter what kind of tire you're running). Even a very good tire pressure gauge is a modest investment, and so is the brief amount of time it takes to use it.
Tombala
