tranny fluid change ... which bolt drains it?
viper04blk
Which one of these bolts drains the tranny oil? the orange threaded one or the silver one?
aaannnddddd is this orange bolt the fill bolt?
thanks
For some reason, my "smart phone" is not showing your pics adequately.
he drain hole is low down on the passenger side of your tranny...torque plug to 28 ft-lbs on installation. The fill hole is high up on the driver's side...torque to 20 ft-lbs as you install plug.
AZTVR
Chandler AZ
thanks
The plugs with the square well in them are the drain and fill plugs. The orange stuff is the sealant that the factory put on there to prevent fluid seepage and/or as a loctite. Not sure that is really necessary.
Ar Tee Ten
