Trunk Problem!
Fastrrr
Naperville, IL
I need help! :p The other day my trunk stopped locking? It closes fine but its not locking? I do not have anything in the truck to stop it from seating all the way down? I also tried it with the top up and I get the same results? I hate the idea of having to bring to the dealer.
Any ideas or suggesstions?
Thanks in advance!
GR8_ASP
Try unlocking it either manually or with the key fob. It may be in the locked position with the tunck open.
GR8_ASP
Armorgod - not quite the same thought. Not yet anyway as I still have 3.07 and no headers. But the rest I have covered!
Skip White
Kingsport TN
I minor adj. should fix it. I had to sort of slam mine shut, a bit harder than I liked, and sometimes very hard. I adjusted the striker, and all was well.
You would think the oh so heavy beast of a trunk lid would latch with it's own weight. Heaviest trunk I ever seen, and it's made from composite material!!
Skip White
N CHARG
Dallas
I had the same issue that Skip had... did the adjustment and all is fine.
