Rolling Thunder
Interested in replacing the stock tweeters in my 2001 RT/10. Can anyone recommend an aftermarket model that will fit with zero modification and hassle? Thanks in advance.
I replaced my tweeters and door speakers without any modification at all. There are plenty of component speaker kits that will fit right in. Don't limit your choice to one brand.
Keep in mind the sound quality is not dependant on the brand but how it's tuned.
I suspect that since you didn't mention the brand or model you bought that one of the following applies:
1. It is a secret.
2. You can't remember.
3. They only made one set. Yours.
4. I must play your post backwards to get the answer.
I didn't mention it because as I said there are many choices and my choice is not the only one. I have the Panasonic component set. Don't remember exactly what model but it really doesn't matter that much. It is professionally tuned and it sounds great. The imaging is somewhat mediocre only because of the tweeter placement. If I get bored one day I'll relocate the front tweeters to the A-pillar and improve imaging a whole lot.
If I was to go into competition then obviously I'd change the tweeters to some really high end ones. But I'm not ready to drop $2,000 on a pair of tweeters yet.
