-B&B Cat-Back, Virtually new, one cosmetically damaged section= $800.00
-Ron Davis Racing Aluminum Radiator w/SS braided oil lines, 500 miles on it, 1.25" tubes, 3.5 inch core, internal oil cooler. Removed due to car sale= 700.00 (250.00 off!)
-99+ Fan Shroud w/larger fan blade and motor, trimmed for a RD radiator, but will still fit a stock rad just fine= 75.00
-Crank Position Sensor
-Throttle Position Sensor
-MAP sensor
-Intake Air Temp Sensor
-Pair of 10K mile front 02 Sensors
-Idle Air Controller
-Coolant Temp Sensor
-Serpentine Belt (4K miles)
-Turn Signal/Flasher relay
-Fuse Box & front wiring harness (complete, but needs 1 pin in headlight connector replaced- I repaired a section of the harness that had been cut after I removed it. Fits 01-02
-Underhood coolant bottle
Some parts are listed on my auctions, CLICK HERE
I will post more as I run accross spare parts....
-MAP sensor
