Updated pics of Paxton Fuel Pumps
BLKSNAKE
Huntsville, Alabama
Decided to get ride of more rubber hoses!
ILLSMOQ
SAN JOSE, CA
I'd try to hide them out of sight.
Also every fitting you add is another chance for a leak........
Matt
San Jose, CA
I was gonna do braided lines with AN fittings...Thats a clean look'n also.
I agree with these guys. It does look clean, but there are alot of junctions there. I'd see about remounting the assembly out of sight and/or using some braided line with appropriate angle AN fittings. Comes out very clean and minimizes connections.
B
BLKSNAKE
Huntsville, Alabama
I agree there are quite a few juntions,but compared to the paxton kit connections it is a lot more stable. I will eventually upgrade further when I figure out where I want to hide them.
Rich
Viper X
Interesting, yes.
I notice that you insulated them as well. Have you taken any temperature readings on the pumps themselves? I put reflective foil on mine and dropped the temp by 15 degrees.
B
BLKSNAKE
Huntsville, Alabama
not yet- just got everything installed
I have only run it a couple of times to make sure everything felt right
After I dyno on Friday I will start playing.
When do the fuel pumps kick in? I have run it through 1,2, and hard in 3- pulls like a frieght train but I have no idea if the pumps are working as I do not have a pressure gauge installed yet.
I have wired the spli-sec, unit to control the pumps.
thanks
B
BLKSNAKE
Huntsville, Alabama
That may be the case-I am a little out of date on my fluid dynamics- but the same would be true of the multiple brass tees that came with the paxton kit.
Guess I will see what the dyno tells me
Rich
Mpcc
